964 engine Management System
I have a 1989 964. I am replacing my stock engine with a 1993 RSA motor. The motor comes with the brain and proformance chip. I was told that a new engine management system would be very useful ...Haltech etc. which is the best system for my car and what are the cost I could expect to have the system installed?
Thanks, Shelon
1989 964 C4- Fikse Wheels -B&B Headers & Muffler - GT3 Seats -RS Door Panels - Club Sport Steering Wheel |
There are lots of choices, none are cheap. Also depends on if you are keeping the stock intake manifolds or using something different.
Motec is one of the most highly regarded
Thanks Bill - The stock intake will remain on the car.
Like Bill says, it's not cheap. Select the management system that your shop is going to be able to support. My shop uses MoTeC so it was a lot less problem to switch to MoTeC than to try and get the Motronic system programmed/re-programmed. A MoTeC conversion is likely to run close to $5k for the ECU, wiring harness, and programming time.
Tom SL63 AMG Daily Driver '92 964 now a GT3R/GTL toy for track fun (Tom's Turtle) |
Thanks for the info. I guess a chip is my inline with my budget.
You are in New York so you should contact Jimmy at The Shop. He is a dealer for Accel Gen 7's.
Do you have Jimmy's contact info? Thanks
1989 964 C4- Fikse Wheels -B&B Headers & Muffler - GT3 Seats -RS Door Panels - Club Sport Steering Wheel Last edited by sgoldberg; 02-19-2008 at 02:25 PM.. |
Yea, he does all of those nasty DFI installs.
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
I wouldnt bother unless you were going to blow into the motor.
I was told that a new engine management system would release hp on the motor. So I figure i would investigate and see what the costs are.
There are ways to gain control over the factory Motronic engine management. Some of the things that are available for the 964 are: MAF conversion, support to larger injectors, support to LWF and access to fuel and ignition without going the standalone route. If you need more information send me a email.
I know this post is old, but I would like to retract my recommendation! DO NOT USE Jimmy Kakaletris owner of The Shop in Norwalk CT. I am beyond mad about my latest experience with him, and his shop!
