Manassas, VA
lucittm's Avatar
Need Help With A Non-Stocked Part
Hey Friends,
(Sounds like I need something, eh)
I was poking around in the front of the cab and cleaning carpet pieces the other day. I pulled the "Cover" off the front lid release lever "Housing" and noticed that the top screw was loose because the brass insert was missing. (See photo below)
I don't want to shell out $72.25 to our sponsor for the whole "Housing" when all I need is one of these small bushings. I could make one if I could get the remaining one out, but it seems to be very happy right where it is.
If someone has an extra one of these "Housings" (964-538-101-000-1C superceeded to 993-538-101-000-1C) and could spare one of the little brass bushings, please PM me at dad10@comcast.net
Thanks,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 01-27-2008, 01:21 PM
The purists will cringe, but since the hole will be covered you could just get a small wallboard molly and push it in there then put the cover one and screw it in.
Old 01-28-2008, 09:32 AM
Manassas, VA
lucittm's Avatar
Need Help...
Craig,
Thanks for the suggestion but the depth of the hole and the associated expanding screw collar is less than 1/4". I can't get a molly to hold it when it is that shallow.
C'mon guys. I bet at least three members of this forum have a 964/993 trunk lid release-lever cover sitting on a shelf and they are wondering why they keep it. This is the reason.
Heck, send me the cover and let me measure the missing brass insert. I will mail it back to you with a token of my appreciation and then I will make an insert myself. I just don't know how to remove the lever assembly or push out the brass insert while the lever assembly is in place (it might have a flange on the back or a retaining ridge?)
PM me here: dad10@comcast.net
Thanks,
Mark
Old 03-01-2008, 07:06 AM
PM me, I can send you one to measure...or I can sell you the entire housing if you need it.
Old 03-01-2008, 09:09 AM
