porsche@964
Guest
Posts: n/a
Question squeeking in engine cooling fan
HELP ME! theres squeeking sound from the cooling fan. what should i do? and how?
Old 03-06-2008, 09:10 AM
kang's Avatar
Is it a fan belt squeak?
Downshift
Old 03-06-2008, 09:55 AM
Don Plumley's Avatar
Probably the fan belt sensor about to give up the ghost...
Don Plumley
M235i
Old 03-06-2008, 03:36 PM
colo964's Avatar
That little bugger can be rehabilitated. I think some JB weld and a new bushing did it. Beats $60.
To be safe, check the fan for wobble - loosen the belts and see if you can wiggle it. It could be the fan hub.
Old 03-06-2008, 07:04 PM
porsche@964
Guest
Posts: n/a
hi kang, nope its not the belt, it sound like metal to metal screeching. and theres a thing i remember regarding cooling fan repair in the forum. because when i touch the fan theres movement. so what should i do or repair the parts or replace it? :
Old 03-07-2008, 04:41 AM
porsche@964
Guest
Posts: n/a
i think your right colo the fan wiggles. so is it the fan hub? what has to be done? thanks colo964
Old 03-07-2008, 05:04 AM
colo964's Avatar
Replace it. Search for part #964 106 051 30. The fan bolts to that hub/bearing. It is probably very tight, but with a pulley tool, sledge hammer, wood block and a few nickels (to protect the 12-point hole on the alternator shaft), you can separate them.
There is a 993 DIY on fan/alteranator removal webpage - http://p-car.com/diy/alternator/alternator.html that gives some good info on how to get most of the way there.
Old 03-07-2008, 06:46 AM
porsche@964
Guest
Posts: n/a
ok i try it out thanks for the info colo
Old 03-08-2008, 09:48 AM
