I wasted plenty of time and money to try and reduce the bump steer using the 964 (original stock) uprights on my car. Once I switched to the EVO uprights (and full monoballs) the issue was solved. Yes, it's a bunch of money, but for a track only car where class rules permit it, it's a great change.
Yes I agree with all that. My car is more geared for drag racing so not worth it in my case.
wheels
964 wheels(mainstream) from the top Design 90, 928 Gullydeckel 16s, Cup narrow spoke, Cup1(akaDesign92)
http://forums.pelicanparts.com/uploa...1225986446.gif the Cup 1, aka Design 92 was also available inthe folllowing sizes http://forums.pelicanparts.com/uploa...1225986999.gif 993 wheels(mainstream) http://forums.pelicanparts.com/uploa...1225986510.gif http://forums.pelicanparts.com/uploa...1225986546.gif http://forums.pelicanparts.com/uploa...1225986568.gif http://forums.pelicanparts.com/uploa...1225986594.gif http://forums.pelicanparts.com/uploa...1225988431.gif In addition to the mainstream wheels there were some specials 964 Cup 1 magnesium, 7 & 9 x17, both ET55 8x17ET52 http://forums.pelicanparts.com/uploa...1225986725.jpg |
964T Speedlines 8x18 Et 52 10x18 ET61
http://forums.pelicanparts.com/uploa...1225987178.jpg http://forums.pelicanparts.com/uploa...1225987203.jpg 993RS Speedlines 8x18 ET52 10x18ET65 http://forums.pelicanparts.com/uploa...1225987521.jpg |
The question of using 996 GT3 gear box has come up, the g96 thru 2000 can be used in a 964 or 993, 2001 up changed to a cable shift mechanism to use those the sfifter would also need to be changed
here's a comparison of the transmissions. http://forums.pelicanparts.com/uploa...1233070935.gif |
Bill,
This might help a little. The pictures of the 3.6T speedlines are actually an aftermarket wheel. Here are a few pics of factory speedlines. these are both polished and painted center versions. http://forums.pelicanparts.com/uploa...1233071606.jpg http://forums.pelicanparts.com/uploa...1233071620.jpg http://forums.pelicanparts.com/uploa...1233071641.jpg http://forums.pelicanparts.com/uploa...1233071986.jpg http://forums.pelicanparts.com/uploa...1233072010.jpg http://forums.pelicanparts.com/uploa...1233072029.jpg If this is too many pictures just tell me what to eliminate |
If so I'll just relable them all pics are welcome, the more the better documented all this is. |
I do have question.....I understand that the 3.6 964 Turbo 18" Speedline Wheel
is the same as the 92 964 Cup Car Wheel. The rear 3.6 964 Turbo 18" Speedline Wheel is a 18 x 10 / 61 mm offset and the 92 964 Cup Car Wheel is a 18 x 9.5 / 47 mm off set. Can I purchase the 3.6 Turbo rear wheel and downsize the inner rim halve to make it fit my 92 964 Cup Car ??? I understand that the 18 x 9.5 is unavialble. Here are some pictures of a customers 18" Wheels.http://forums.pelicanparts.com/uploa...1233111344.jpg http://forums.pelicanparts.com/uploa...1233111366.jpg |
PM sent. |
964 & 993 road test performance data is summarized Here
805-498-7261 jdorociak@gmail.com Has done a lot of work refurbishing and modifying outer/inner combinations of the various Speedline wheel sets |
I understand these are a compilation of different magazine tests of the time and that there are numerous factors that come to play. However, can any of these numbers really be the truth. There are variations and exaggerations that I don't think could be achieved by some of these cars even if they were treated in a brutal fashion with a full drop of the clutch from very high rpms. Car & Driver IMO had always reported ridiculous numbers that most factories wished their cars would perform at but know they are not capable of. I would love to find the RSA that C&D claimed did a 4.6s 0-60 time and although I would love to believe my turbo is capable of 4.0 seconds flat in stock form but I think I would be needing a new clutch and tranny after 4 or 5 launches like that. With the mods it is far easier to obtain but still not what these cars were meant to do. I find Auto car and top gear #'s to be the most realistic with Car & Driver in a world of it's own. |
I am a bit surprised to read that the 993 has a higher drag coeff. than the 964. Granted I had just gotten my license when the 993 came out, but I could have sworn that I read the revised bodywork of the 993 was more for aerodynamic purposes as opposed to aesthetics. Was this a case of the original intent to be one thing but through development, ie the addition of the picnic handle, you end up with a production vehicle that has gone array from the original intent?
The 993 had wider hips due to the redesigned rear suspension. That's what made it less aerodynamic.
http://forums.pelicanparts.com/uploa...1205964342.gif As Ilko mentioned the rear fenders are much wider on a 993, makes lots of room for wheels, tires and mufflers but not so good for aero. I'll add that the front fenders are also wider, again great for fitting big wheels and tires not so good for aero. JMO, aero isn't all that important in and of itself, I prefer a balance of aero and pleasing looks. A 996 aero wise has it all over 964 and 993 but is just too plain for my tastes. |
In pounds then the 993 RS has 40 pounds of lift at the front 0 at the rear. The 993 RS Clubsport has 0 pounds lift at the front increasing to 40 pounds of lift at the front when the rear wing angle is increased to nine degrees. The 993 RS Clubsport has rear downforce increase from 26 pounds at zero rear wing angle to 160 pounds at nine degrees angle So, the RS Clubsport front lift goes up as rear downforce goes up. Frere in his book states the 993 has a higher rear lift number than the 964 because "the exhaust system makes it impossible to raise the (engine) underpan at the car's rear end" (as the 964 does). So, an interesting data point would be that of a 964 Carrera Cup car which would be a 964 without the engine underpan which would presumably add to lift at the rear as Frere states. Data for the RS America whould be interesting since this adds the bigger wing to the 964, perhaps generating downforce at both ends, not just the front. |
| All times are GMT -8. The time now is 12:42 AM. |
