993 misfire
my check engine light came on the other day and the codes came up as random miss in all cylinders. the car has 60k miles so i did a tune up (plugs, wires, cap, rotor,and air filter) the check engine light came back on with the same codes. is there any known problem that can cause a the check engine light to come on like this? could i change the coils? someone told me that the use of anti-size on the threads and dielectric grease on the contacts of the plugs can cause a bad contact and maybe even a miss, is the true?
Thanks. |
Max Sluiter
The air injection system will screw up OBD2. The air injection ports in the exhaust become clogged with carbon, if I remember correctly. The O2 sensor doesn't like it and the check engine light comes on.
I am not a late model guy, though. Wait for Bill V. to answer your question and do what he says.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Flieger: You are confusing the SAI CEL with the Misfire CEL.
Here's a general list of misfire causes: Non OEM Fan belt O2 Sensor, Wiring Vacuum Leak MAF dirty Dirty Injectors Ignition: Wires/Caps/Rotors/Plugs worn Various Hall sensor issues Failing Dual Mass Flywheel and rarely, wearing valve guides. I might suspect anti-sieze causing an ignition problem. Does your engine idle rough when warm or are you just throwing the code?
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
If I recall correctly, the factory service manual specifically states NOT to use anti-seize on the spark plugs. The factory recommended plugs have a coating on the threads that prevents galling, just like the anti-seize would.
Perhaps the anti-seize you used, even if not near the firing gap of the plug, is preventing the plugs from getting a good ground via the heads. You might consider removing the plugs, cleaning the anti-seize off as best you can (hard to get into the heads to clean in there) and see if that makes your codes go away. I don’t think dielectric grease on the electrical contact part, e.g. the plug wire, would cause any problems.
Downshift Last edited by kang; 03-28-2008 at 08:32 AM.. Reason: typo |
Max Sluiter
Could anti-seize also inhibit heat conduction from the spark plug into the head, thereby causing the spark plug to run hotter and cause detonation?
it doesn't idle 100% smooth but i have heard it was normal for 993s to have an idle that wasn't perfect. if you don't mind me asking how can a non OEM fan belt cause a misfire?
Because they can slip then catch, slip then catch altering or pulsing the flywheel mass of the entire assembly. Don mentioned all of the known and typical causes. Non-factory belts and a failing DMF are the two most common. |
The non-factory belt issue is an often overlooked and fortunately easy to solve problem. Apparently there is slight slippage which causes a problem with the crank position sensor reading accurately, which throws the misfire MIL.
To check you belt tension, Napa auto parts sells an $11 Kriket belt tension checker which is identical to the Porsche tool. ![]() Item#: NBHKR1 Price: $10.08
thats great. that will be the first thing i do. thank so much for all the guidance!
Check to make sure you did not switch the firing order when you replaced the cap.
or You may have a faulty belt connecting your two distributors or one of your spark coils is not getting a spark toone of the distributors. On my car the car runs smoothly on the primary distributor It runs rough on the secondary. I just unplug the wire from the coil to one of the distributors to see if the other distributor is working. Andy |
