What size offset for my 3.6 turbo 2
Need Help!!!
Anybody know if these size wheels will fit my 1993 964 3.6 turbo?
FRONT 8 1/2 x 18 ET52 with BRIDGESTONE 225/40ZR18
REAR 10x 18 back ET47 with BRIDGESTONE 265/35ZR18
If not what offsets can i have?
Old 05-27-2008, 09:34 AM
If your car had the Speedlines 3.6 Turbo wheels they were 8 ET 52 front and 10 ET 61 for the rear. Jim
Old 05-27-2008, 09:00 PM
FRENCHMAN
dypascal's Avatar
you can use 65/61 at rear.Porsche approved.But I have no clue for 47.
Pascal
964 TURBO 91 RED ARENA WITH SOME LITTLE MODS
911 3.2 CARRERA 86 SOLD BUT NOT FORGET
Old 05-27-2008, 09:40 PM
well basically the wheel is going to sit 14mm further out than stock. It is probably going to be a tight fit.
I would suggest you identify the wheels by brand and model that you are looking at and possibly someone has used them and can accurately comment on their fit. Jim
Old 05-27-2008, 09:49 PM
Thanks chaps,
I never had any speedlines on mine when I bought it.
The wheels i'm looking to buy are speedlines advertised privately for £1200.
I'll keep on searching!!!
Old 05-27-2008, 11:08 PM
If they are Speedlines they must not be the 3.6 Turbo Speedlines, which would have either come on your car, or been an option that most purchased.
I have seen Speedline Alesio 8 ET 45 front and 10 ET 56 work -- Jim
Old 05-27-2008, 11:33 PM
I think your right. They have sort of slanted eye-holes. My laptop settings won't allow me to up load a pic.
Old 05-29-2008, 01:34 AM
If they have an elongated area for the lug bolt they are probably Speedline Alesio wheels. They were manufactured by Speedline but designed to fit many cars, so where the lugs go is then drilled specifically for different cars, Jag, Austin Martin, Ferrari, Audi, Mercedes.
Jim
Old 05-29-2008, 06:02 AM
Thought this might help in your search....I have a set of Fikse Mach 5's sized specifically for a 91 C2 Turbo. The sizes are;
Front: 18x9" 57mm offset
Rear: 18x10.5" 51 mm offset
Old 05-29-2008, 08:05 AM
