993 TT Big Red Brakes
Does anyone know the trick for removing the dust boot on Brembo Big Reds?
Old 05-26-2008, 03:49 PM
North Coast Cab's Avatar
I use one or two small straight blade screwdrivers to "pry" the boot up. There is a metgal band inside the rubber boot, just be careful not to mar the outer surface.
1985.5 944 GTS
Old 05-26-2008, 04:53 PM
So there is no clip to remove, you just have to work it around the piston?
Old 05-26-2008, 06:02 PM
davisriley's Avatar
No, no clip. The outer band, the side at the caliper has a metal ring in there that holds it's shape and pressure fits it into the bore, and in the center, around the piston, the seal just streches a little and fits into the channel at the top of the piston.
1991 C4-edging further away from stock
1972 T-Incoming project
Old 05-27-2008, 06:09 AM
I guess that based on the last post, I am looking for the proper way to remove the press fit metal ring. Does the "two screwdriver" method used in prying the metal band up? If so, sorry, I thought that was used for working the boot around a piston that is being inserted.
I have to replace a dust boot that is torn.
Old 05-27-2008, 10:10 AM
davisriley's Avatar
Sorry, I don't know the answer to that. I actually got my calipers apart, and put them together, so don't know the best way to pull the seals. I'm sure someone who has done one will chime in.
Old 05-28-2008, 01:59 PM
Bill Verburg's Avatar
there are 2 seals an inner pressure seal and an outer dust seal
here's a piston
here's a dust seal
here's the seal installed, work it in by hand or watha plastic ladle
there was a more complicated older design that used a ring, it looked like this
Bill Verburg
Old 05-28-2008, 02:10 PM
Bill,
Seeing the picture of the seal by itself made things very clear, thank you.
One other question if I may. The old seal was firmly in place, when I press the new one in it is quite easy to pull out. I made sure the seal and seating surface were clean. Should this be expected?
Thanks again,
Thom
Old 05-28-2008, 06:11 PM
