-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Dashboard (Fan) squeek question... (http://forums.pelicanparts.com/porsche-964-993-technical-forum/420735-dashboard-fan-squeek-question.html)
LaurenLynn 07-18-2008 07:07 PM
I turn up the fan knob (left of Temp Control knob) and hear increasingly louder squeeking. Higher i turn fan speed, louder the sqeek/hum/creaking sound. Is this time for Heater Blower Motor replacement ? If not, what's doos i need to do ? This is on our 964 ('90 Carerra 2).
Thanks a bunch...
LaurenLynn
LaurenLynn 07-19-2008 05:07 AM
Squeak Question Please
Bumpity :)
Hamptonsam 07-19-2008 08:19 AM
Is the sound coming from the front trunk? If so, sounds like one of the front blower fans is about gone. I had the problem with the squeaking noise. I replaced the left front blower with a used fan. Solved my problem.
LaurenLynn 07-19-2008 09:13 AM
Squeek in dash
hi...
squeek source sounds like right in dash area 2 feet or so from our noses.
someone told me could be heater blower motor. is this motor close in center of dash ?
LL
Hamptonsam 07-19-2008 09:24 AM
There are 4 fans that are part of the ventillation system. In the engine compartment, there is a heater blower on the left side. This does not sound like your issue.
On the Climate Control Unit (CCU), there is a very small fan in the back of the unit that cycles air to verify the temp. You would hear the squeak low by the CCU.
There are 2 fans (one either side) just in front of the dash. These are located near the fire wall in the front trunk. These fans do have a tendancy to wear out. I had the left side fan wear out and it squeaked louder depending on the setting on the fan. Eventually it stopped working unless on setting 4. Those fans are not cheap, so I got one from a dismantler. I installed it myself which is a little tricky. Just did not have the money to spend to have someone else do it.
Good luck.
LaurenLynn 07-19-2008 09:57 AM
Fan Squeek/Squeel
Any further discourse on this topic well appreciated.
HamptonSam thanks so much for that already shared in this thread.
LL
kang 07-21-2008 08:47 AM
Sounds like blower fans to me.
