Banned
Dashboard (Fan) squeek question...
I turn up the fan knob (left of Temp Control knob) and hear increasingly louder squeeking. Higher i turn fan speed, louder the sqeek/hum/creaking sound. Is this time for Heater Blower Motor replacement ? If not, what's doos i need to do ? This is on our 964 ('90 Carerra 2).
Thanks a bunch...
LaurenLynn
Old 07-18-2008, 07:07 PM
Banned
Squeak Question Please
Bumpity
Old 07-19-2008, 05:07 AM
Is the sound coming from the front trunk? If so, sounds like one of the front blower fans is about gone. I had the problem with the squeaking noise. I replaced the left front blower with a used fan. Solved my problem.
1990 964 C4 Cab
2008 Range Rover Sport (daily driver)
Old 07-19-2008, 08:19 AM
Banned
Squeek in dash
hi...
squeek source sounds like right in dash area 2 feet or so from our noses.
someone told me could be heater blower motor. is this motor close in center of dash ?
LL
Old 07-19-2008, 09:13 AM
There are 4 fans that are part of the ventillation system. In the engine compartment, there is a heater blower on the left side. This does not sound like your issue.
On the Climate Control Unit (CCU), there is a very small fan in the back of the unit that cycles air to verify the temp. You would hear the squeak low by the CCU.
There are 2 fans (one either side) just in front of the dash. These are located near the fire wall in the front trunk. These fans do have a tendancy to wear out. I had the left side fan wear out and it squeaked louder depending on the setting on the fan. Eventually it stopped working unless on setting 4. Those fans are not cheap, so I got one from a dismantler. I installed it myself which is a little tricky. Just did not have the money to spend to have someone else do it.
Good luck.
1990 964 C4 Cab
Old 07-19-2008, 09:24 AM
Banned
Fan Squeek/Squeel
Any further discourse on this topic well appreciated.
HamptonSam thanks so much for that already shared in this thread.
LL
Old 07-19-2008, 09:57 AM
kang's Avatar
Sounds like blower fans to me.
Downshift
Old 07-21-2008, 08:47 AM
