help please ! need reply right spacers
Ok my situation is I have carrera traga c2 , I don' like the 90 desine wheels, I have original set factory like new of porsche twist 18s, with pirelli almost new I got from a good friend of of 2001 carrera, may people recommend just 17s in the 964 , and said I will need spacers, and roll the fender, and move oillines all kind of shhhhit, so i make my mind to sale the 18s and sale the 16 original and buy a good factory 17 cups 2 or 1 , I have been looking in ebay and aorund for 4 wekks and nothing! good! I wast thinking i have factory set of 18 with tires perfect shape sitting in my garage why I looking to get other set and sspend more money! ok so i will like to try to use what I have 18s twist with tire ,
ok the real help, I will like not to touch the fender at all ! I don't like to roll them, and not move any oil lines , will they fit with right spacers? tire are fronts 225 18 40 rims 7.5 18 off set 50mm rear 265 18 35 rims 10 180 off set 65mm I WANT HONEST RESPOND REAL HELP SOMEONE ALREDY HAVE HAD TO DO THESE, i WHERE I WILL NEED SPACERS ? WAHT WILL BE JUST RIGHT SIZE? 15MM 21MM 25MM? LATS ONE WHERE I CAN GET THOSE SPACERS IN A GOOD PRICE?? I IMAGEN WILL NEED THE ONE THAT COME WITH STUDS?RIGHT!!! HERE IS PIC OF MY CAR AND HOW i WILL LIKE TO LOOK LIKE OFCOURES I DIDN'T FIND THE CUPS 1 17 BUT i GUESS THESE TWIST WILL LIKE EVEN BETTER?? thanks for all help -- ![]()
The Speedline Look from RH Wheels
You could buy the wheels & tires that I have for sale and they will bolt right up to your car with only a 5mm spacer in the rear and no spacer in the front.
FS: RH 3.6 Wheels (Speedline look) It would look something like this:
Dan 88 930 blk/gry |
3000.00 is way too much money I don't care what are they made of or from, and still take cups 1 anyday of de weeks your speedline I don't like them!
no anyhelp with spcars please! |
The free world is a great place - full of choices. I take the time to put a solution in front of you and you made a decision to be rude about it. To each his own. Have a nice day.
Please any help with my problems what are right spacers? to used and where get them?
You don't need spacers in front BUT you will experience some slight rubbing at full lock. You'll notice it when backing out or fitting into a tight parking spot, most likely.
The rear wheels you described have too large an offset, 65mm, which pushes them inward towards the car. The tire will rub against the trailing arm, oil line, etc. under load. Ideally, you want a rear offset of approx 50mm, so a 15mm spacer will give you adequate clearance. And, yes, I have a pair of spacers (with studs) to sell. Send pm if interested.
J Martinez Highland Park, IL 1990 C2 Coupe PCA Prepared G Class Race Car |
