Bill Verburg's Avatar
2 theories of air cleaner covers
Air cleaner covers
here's 2 ways to do it
Factory motorsound and jigsaw
Bill Verburg
Old 08-06-2008, 12:24 PM
Now in 993 land ...
aigel's Avatar
One could also use a hole saw and make it look a bit better? Ideally I'd give it to a buddy with a CNC and have it drilled with the exact pattern the factory piece has!
G
81 SC (sold)
Old 08-06-2008, 09:59 PM
There are lots of things you can do, CNC is not something that I would bother w/
I can't really say that I notice a difference between either of the above versions or the third unmodified normal version other than a little more noise from the holey versions
Bill Verburg
Old 08-07-2008, 03:20 AM
Now in 993 land ...
aigel's Avatar
Mine has been modified with a saw. Clean job though. The noise is music!
George
81 SC (sold)
Old 08-07-2008, 08:32 AM
jackb911's Avatar
I did mine with a $11 Harbor Freight hole saw kit.
Jack
2007 GT3
gone but not forgotten: 1987 Carrera IROC backdate, '89 Carrera M491, '96 993, '93 964 RSA(two), '00 996, '97 Boxster, '79 911SC, '78 928, '76 924, '75 914, '74 911, '74 914, '72 911E, '72 911T/V, '71 911T, '70 911T, '66 912, '65 356C, '61 356B roadster, '60 356B
Old 08-07-2008, 10:16 PM
The bigger the hole the better the flow potential that's fer sure.
Bill Verburg
Old 08-08-2008, 03:36 AM
Dan (almaden)'s Avatar
I have one of these in Carbon Fiber for my C2
Lucky for me it was on the car when I purchased it, since I don't think I would have dropped the money on one....would have made my own.
this is just a big hole, not much left but an edge to hold the filter in place!
Old 08-08-2008, 12:16 PM
where you can buy that carbon fibers covers?how much
Old 08-08-2008, 05:15 PM
Sports Purpose 911 Driver
mjshira's Avatar
I just put a cone filter on
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 08-08-2008, 07:28 PM
kang's Avatar
There is another option.
The inlet tube, where the air first enters the air box (the part that’s chrome on the motorsound box), easily snaps out of the air box. This makes the opening significantly bigger and eliminates the tube that follows (you can see the end of this tube in the left hand picture of Bill’s post).
Use a small screwdriver to pry the tabs that hold this piece in. It pops in and out easily. No permanent mods necessary. Cost = $0.
When you remove this piece, you will draw slightly cooler air from the front of the engine compartment. The holes in the motorsound box draw air from further inside the engine compartment, where it is slightly warmer. This difference is worth .001 HP.
You can also remove the clutch air vent, and push it to the side. Put a small filter over this air vent so clutch dust doesn’t spread all over the engine compartment. Removing this vent opens up another big hole in the air box cover.
Downshift
Old 08-11-2008, 09:31 AM
She/Her
BeauBlues's Avatar
I just finished drilling my air box cover. First off, I didn't expect any benefit from this at all, but I must say the engine has a noticeable growl now. I really like it. Definitely one of those no brainer, no cost, worthwhile upgrades! I don't have any pictures, but I drilled it similar to the motor sound cover, just with slightly bigger holes.
Gwyneth *she/her
1995 993 Guards Red
1984 911 Targa with a G50 (RIP)
Old 08-12-2008, 09:11 PM
