'91 C2 Cab
Brake/clutch fluid recommendations?
All,
I am changing/flushing the brake/clutch fluid and am wondering what fluid do you recommend I use in my stock '91 C2? It is not a daily driver, nor is it track driven. I see some new products out there that are claiming to be DOT 3 and 4 and say synthetic on the bottle. Is it okay to use synthetic in these cars? Thoughts?
Thanks!
'91 C2 cab 50K miles box stock, driver, just not daily.
"I never cease being dumbfounded by the unbelievable things people believe."
Leo Rosten
Old 04-01-2008, 07:26 AM
Don Plumley's Avatar
For daily purposes, I would stick with standard high-grade brake fluid.
Don Plumley
M235i
Old 04-01-2008, 07:31 AM
'91 C2 Cab
I have some fresh Castrol, is that a good "high grade"?
Leo Rosten
Old 04-01-2008, 07:40 AM
Newsboy's Avatar
I have used ATE Super Blue. Around $12.00 per liter. The blue color lets you know when the old stuff is gone.
Old 04-02-2008, 12:11 AM
Bill Verburg's Avatar
There are different grades of Castrol(and other brands)
Castrol LMA is ok, though there are better choices for track use
Casrol SRF is among the best(and most expensive @3-4x the cost of most other choices)
ATE blue and ATE200(same stuff except blue is 200 w/ dye) are very good moderately priced fluids
other excellent and reasonably priced brands, though more expensive than ATE
Motul RBF600
Brembo LCF 600
Bill Verburg
Old 04-02-2008, 05:08 AM
'91 C2 Cab
Thanks to all,
I finished up with the change, what a snap with the Motive power bleeder! I also replaced the slave cylinder hose, I heard they deteriorate over time. That was not too bad of a job either. Long arms skinny arms help. My car will not see track time, so I used Castrol LMA.
Loving the warmer weather!!!
Thanks again!
Jeff
Leo Rosten
Old 04-03-2008, 04:03 AM
Hi Jeff,
I've been wanting to replace my brake fluid for some time. Could you provide some instructions on how best to do this or some web links
Many thanks,
Colin
Old 04-08-2008, 07:46 AM
JoeMag's Avatar
there was discusison on rennlist race board about this about a month ago and Casrol SRF was deemed to be the best (race aps) because it has the highest WET boiling point.
Old 04-08-2008, 08:46 AM
There is no doubt that SRF is among the very best, but compared to very good ATE200/Blue you get ~28% better performance @~700% higher cost
SRF compared to Motul 600
is ~10% better @ ~290% higher cost
If you need it it's worth every penny but most people don't need it.
Bill Verburg
Old 04-08-2008, 09:21 AM
kang's Avatar
What brake fluid does the factory recommend? Somehow I recall Pentosin, but I could be wrong on that...
Downshift
Old 04-08-2008, 09:25 AM
Factory fill is ATE200, they even used that on the GT2 Evo race cars
Bill Verburg
Old 04-08-2008, 09:38 AM
Originally Posted by voodoo964 View Post
Hi Jeff,
Many thanks,
Colin
Easiest with a Motive Power Bleeder.
Raise the car, remove the wheels. Clean the bleed nipples.
Suck excess fluid from the reservoir with a baster or syringe.
Pressurize system with bleeder to ensure it seals (clamp overflow hose if your car has one).
Push through one pint of new generic fluid to flush system. Don't forget the clutch slave cylinder.
Add ATE200 or equivalent new fluid, push through all 9 nipples (RR, LR, RF, LF, Clutch).
Test brakes for firm pedal before remounting wheels.
Don Plumley
M235i
Old 04-08-2008, 09:46 AM
Thanks for that don!
Old 04-08-2008, 10:01 AM
'91 C2 Cab
voodoo,
It really is as easy as Don mentioned. The key is using the proper tools, Motive Power bleeder for the flush and a Mity Vac is a handy tool to use to suck the reservoir out before beginning the flush. Be careful when opening up the bleeder valves by using a proper fitting wrench. Oh, and long arms help when you are trying to get to the slave cylinder bleeder.
Let us know how it goes!
Leo Rosten
Old 04-09-2008, 02:26 AM
Bled the brakes but didnt have time to do the clutch will do it at weekend. Its pretty easy, of course it helps to clamp the overflow hose
was wondering why i lost all pressure - got it back again
Thanks for the help!
Old 06-27-2008, 04:02 AM
when bleeding 9 nipples i presume each caliper has 2, which one is opened first, top or bottom
is it the same sequence for the 964 turbo
Old 09-08-2008, 03:07 PM
I dont know if anyone mentioned it but make sure you bleed that round accumulator in the trunk as well. And make sure you clamp off the overflow hose from the resevoir. You have to unhook the hydraulic pump and go through that procedure to do it.
JERRY
2011 Cayenne
2007 997 Turbo
1991 964 Turbo
2005 955 Cayenne
Old 09-08-2008, 08:14 PM
There is never a bleed nipple on the bottom, inner 7 outer on top only
only the electro-hyd boost systems(C4,tt,RS, 964t) have an accumulator in the trunk
the general rule of thumb is to bleed from the furthest to the closest to the m/c
Bill Verburg
Old 09-09-2008, 04:57 AM
could someone please run through how to bleed the full 964 turbo system from brakes to clutch to the accumulator, what does this accumulator look like and when and how is it bled
the fluid needs changing anyway
Old 09-09-2008, 03:39 PM
