About to replace dual distributor belt
Anyone can inform me how to set engine to Z1 #1 TDC without pushing the car or turning the wheel while car is on a lift?
What size offset box wrench will turn the flywheel pulley bolt? Am about to pull the distributor out for replacement of the rubber belt. |
Remove the caps and check where the rotor timing marks are.
Remove vehicle from lift and push vehicle in gear until they line up. Place car in neutral and check the crank marks agaiin. Remove distributor. Mark everything before removal of anything!!!! Or: Turn engine over on alternator pulley nut, you may have tension belt with your other hand so it will rotate engine.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
Thanks,
What is the size of the crankshaft pulley bolt? |
I highly recommend you disconnect the neg battery cable and put a big note on the engine and on the dash to remind yourself not to disturb the engine position. I also put white marks on the pulley in a couple of different locations just in case.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
I have been doing this for a while until somebody suggested to use a remote starter switch. After getting hold of a remote starter switch for $15 from the auto parts store, I just found it very safe and convenient especially when finding TDC and adjusting valves.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
Thanks all,
I'll get on with the project next weekend. |
+1 on the remote starter. It makes things so much easier
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Sports Purpose 911 Driver
lots of good advice here. I'd recommend Adrians book also, it shows the process very clearly.
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
