-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   rusty rotors on stored 964 (http://forums.pelicanparts.com/porsche-964-993-technical-forum/447661-rusty-rotors-stored-964-a.html)
CPBMD 12-22-2008 03:54 PM
My 964 C4 has been off the road for a month. I have it in my garage hooked up to a Porsche trickle charger. I noticed today that the rotors have a coat of rust on them. The weather is erratic here in NH with very cold dry days and warmer damp days. Are my rotors getting ruined? Is there anything that I can put on the rotors to prevent this? Should I drive the car back and forth in my driveway using the breaks to clean the rotors or should I just forget about it?
Thanks for the input
Constantine
MarKoBrow 12-22-2008 04:28 PM
Drive the car on a dry day, rust will go away
kurquhart 12-22-2008 04:40 PM
The rust is often caused by putting the car away with cold, wet brakes. For example, after I wash my car in the driveway, I take it for a spirited run to get the brakes hot. Driving home in the rain usually does not cause rust, since the hot rotors will dry quickly once in the garage.
Not sure if this is true or not, but I have heard that the rust on the inside of the brake rotors is far more damaging than what you can see on the outside.
CPBMD 12-23-2008 03:49 AM
Thanks for the advice. If it ever stops snowing around here I will get the car out for a ride.
Cons
davidbob 12-24-2008 02:33 AM
just forget about it.
do not pay much attention towards it.
CPBMD 12-25-2008 07:05 AM
Great! That was what I was hoping to hear.
trader220 12-25-2008 08:31 AM
They're cast iron rotors they're going to get urface rust. Walk a new car lot and see how many brand new cars which have been sitting after a rain get surface rust, its no big deal.
CPBMD 12-25-2008 09:11 AM
thanks
SNOWBIRD 12-27-2008 04:51 PM
Mine lives 60' from salt water and gets that much rust in 2 days. Nothin to it
