Check Engine Light pin at DME
For a 1991 964, which pin on the DME is for the check engine light output to the light
Okay...Why do You ask?
90-964-cab |
Doing a 3.6 conversion. Want to connect up a CEL (and not one that fakes it by using the alternator.)
According to My Bentley Technical Data book for '89 and up 964's...Pin # 22 of the Engine Control Module (DEM) is the" Check Engine Control" pin.
Hope This Helps. Tony
90-964-cab |
