-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   1997 993 stalling problem (http://forums.pelicanparts.com/porsche-964-993-technical-forum/469880-1997-993-stalling-problem.html)
Rick Cabell 04-19-2009 06:04 PM
I took the 993 out for the first time in a month. Right off the bat it stalled at the first traffic light. Then again every time I came to a stop. It would only stay running if I kept my right heel on the throttle as I came to a stop. It would start right back up, and idle pretty good. It's on a deceleration stop and you push the clutch in as you come to a hault. NO check engine light is on. This went on for about a 25 miles road trip. Any thoughts?
Don Plumley 04-19-2009 09:16 PM
Clean your ICV (Idle Control Valve)?
Do you have a LWF? If so, leave the AC on to raise the idle.
Rick Cabell 04-20-2009 05:05 AM
Haven't touched anything yet. What is a LWF ?
Bill Verburg 04-20-2009 05:15 AM
single mass 'light weight flywheel' as opposed to the stock dual mass and very heavy flywheel.
I agree w/ Don, clean the ICV, it's easy enough to do. also check for vacuum leaks, I had one on the '95 engines that would cause the stalling you describe but only when AC was on. Repaired the leak and never had another problem.
O sensors can cause cold stalling but that doesn't sound like your issue.
Paul K 04-20-2009 06:45 AM
I replied to your identical Rennlist post but again...
Have you disconnected your battery recently?
That might be the cause. I just went through the same thing and it was caused by my having disconnected the battery. The good news is that it'll fix itself if so.
Paul.
Rick Cabell 04-20-2009 06:48 AM
Matter of fact, yes, it was right after I took the battery out for a full recharge and re installed it. I'll check the other ideas also, Thanks guys.
jimz993 04-20-2009 10:08 AM
1+ on ISV.
But be very careful when cleaning it, you can damage the electric component inside. If that happens get ready to buy a new one!!
It happened to me!!!
Paul K 04-20-2009 10:21 AM
Rick:
If the problem was caused by disconnecting the battery, you need to drive car car so it can 're-set' its self. Worked for me!
Paul.
