Clutch issue
What can be wrong after I replace the clutch valve, slave, and the flexible hose to the slave, bled all the system twice. The pedal was very smooth and very quiet. So today I use the car for a few hours and now the pedal is not that smooth and the salve is noisy again. I don't know what else to do!!
Any comment will be much appreciated!!
1997 Carrera S |
Did you lube the end of the slave rod?
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Yes I did...
Could it be the clutch then?
1997 Carrera S |
Could be the fork and cross shaft needle bearings starting to bind. The needle bearings could have dried up and lost the grease lubricant. I have the same problem. I am getting ready to drop my transmission when my Maxjax lift is installed.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
