Whirring/whining sound under deceleration and at idle
I have an odd whirring/whining sound coming from the rear of the car. If the clutch is 1/2 to fully depressed I get nothing. If the car is under acceleration, nothing. However, at idle with the clutch out and in neutral or when I lift off the throttle while in gear I get a whirring almost siren like sound almost like when you have an AM radio on while going under a metal bridge. I have some opinions that say the throw out bearing is shot others saying it's the pinion bearing(s). Otherwise the car functions as normal. I had the problem for a few days last fall then it vanished. This years it has reared its just this past weekend after a months use without incident.
993 C4 6sp. w/RS lightweight flywheel and clutch. Thanks in advance for your advice.
1995 993, Guards Red, RS Clone in Progress 1975 911S, Silver. Almost done... |
Nice stable - have any pics?
Certainly has a bearing like feel to it, wonder if it could be syncros? Fluid level in the tranny? Any evidence of seepage from a RMS or Nose seal? You might ping Noah and ask him to look at the thread...
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
There is no seepage at all from the engine/tranny. I added just a little bit of Swepco to the tranny last fall and it "seemed" to cure the issue but it's back now very intermittently. I have no problem just replacing the TOB as it's a fairly minor expense item and not a huge amount of time. Pinion bearings are a different story though. If indeed it is the pinion bearing I might be better off getting a rebuilt transmission cost wise. By most measure it will run me about $3k to rebuild it or about the same to get a rebuilt one with some sort of warranty. I would be more interested in getting a rebuilt transmission with RS type gearing if possible too. Heres the 993 from an Auto-X last fall.
