ahead of the curve
Jeff Burger's Avatar
need help - 964 big brake install
I am doing a big brake upgrade on a 90 C2. I read somewhere (on this forum I think) that I should up grade to the 993 master cylinder so I went out and bought one without doing any other homework . the 993 master does not appear to have any chance of working with the 964 Vaccum booster. for starter there is the obvious differnce in the design but not as obvious the seal diameter is smaller than the opening to the booster - I could use some help from someone who has BTDT.
Also I purchased the larger resevoir in the picture. how difficult is it to remove the securing piece across the bottom of the resevoir - any chance of damaging the resevoir ?
TIA
regards
Jeff Burger
845-590-5355
Old 07-18-2009, 04:18 AM
Bill Verburg's Avatar
Go down to post #18 here
you need the following parts
993 vac can 993.355.023.10
gasket 993.355.301.00
bracket 993.355.163.03
and either 993 lines or adaptors.
lines and adapter sources
Classic tube
Plews-Edelman
Fedhill
p/v
use
964.355.305.10 55 bar stock on all 4 piston rear C2 & 964RS
or to get a little more rear bias 964.355.305.01 60bar, some remove the p/v entirely
the BMW 10mm to 12mm brake line adapter part #
34-32-6-752-405
Bill Verburg
Old 07-18-2009, 04:34 AM
ahead of the curve
Bill
Great info - I guess I didn't dig deep enough into old threads - thanks you so much
Jeff
Old 07-18-2009, 12:08 PM
Your car sounds great!!
here's the mc measurements
thanks!
Bill Verburg
Old 07-18-2009, 03:01 PM
ahead of the curve
Bill,
ok so I will never make it as a draft person - let me know if you need any other measurements
Old 07-19-2009, 10:50 AM
ahead of the curve
part # for the above 99335591000
Old 07-19-2009, 11:03 AM
Thanks!, that's perfect. You going to be at HV/ LRP next week?
Bill Verburg
Old 07-20-2009, 05:10 AM
ahead of the curve
unfortunately I will still be putting the car together
Old 07-20-2009, 06:44 AM
