-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Can You Tell Is you have the updated P & C's (http://forums.pelicanparts.com/porsche-964-993-technical-forum/490934-can-you-tell-you-have-updated-p-cs.html)
LM3929 08-10-2009 07:17 PM
Is there some way of telling if your 964 engine has the updated Cylinders and Pistons without tearing the engine down?
Thanks Lorne M.
911Urge 08-10-2009 10:48 PM
Thanks Lorne M.
Possibly - If the shop that performed the work followed the Porsche instructions there should be a mark as shown in the attached image.
"Mark cylinder head with -10 or -20 appropriately on intake flange"
http://forums.pelicanparts.com/uploa...1249969701.jpg
LM3929 08-11-2009 09:38 PM
Thanks I will check for the marks.
Lorne M.
rattlsnak 08-12-2009 08:46 PM
What was this update for? (I know of the cylinder gasket update issue only)
LM3929 08-12-2009 08:53 PM
That's the one
Lorne M.
LM3929 08-14-2009 04:56 PM
anyone have more info on the whole job?
thanks lorne m.
rattlsnak 08-14-2009 07:16 PM
the update was removing the heads and machining them to fit a gasket to them to stop the leak. only a few needed replacing the cylinders for that problem, never the pistons..
LM3929 08-15-2009 01:52 PM
Thats the info that I am looking for what actually the TSB from Porsche says.
Lorne M.
911Urge 08-16-2009 09:39 PM
That specific TSB "Refacing Cylinder Heads" (as well as many others for the 964) can be found at http://www.pcarworkshop.com/index.php/964_-_TSBs%2C_Parts_Guides
You must register at the site (its free) to see the TSB's
Rahul 04-02-2021 08:02 AM
I had also bought new mahle cylinders for 964 & send cylinder head for refacing to a reputed company, now I need to know if i have to do engine timing differently or I need to measure piston valve clearance separately, as head has been machined ... My engine is 964, 91 Carrera 2.
