Can You Tell Is you have the updated P & C's
Is there some way of telling if your 964 engine has the updated Cylinders and Pistons without tearing the engine down?
Thanks Lorne M.
83 SC |
P-Zero Burner
"Mark cylinder head with -10 or -20 appropriately on intake flange"
Stephen 2006 997 Carrera S - Sport Chrono, Full Leather 1968 912 - Purchased from Vasek Polak in 1971 and still in the family ----- 1989 Carrera 4 - Andial service history, Sold and missing it |
Thanks I will check for the marks.
Lorne M.
83 SC |
Insert Tag Line HERE.....
What was this update for? (I know of the cylinder gasket update issue only)
That's the one
Lorne M.
83 SC |
anyone have more info on the whole job?
thanks lorne m.
83 SC |
the update was removing the heads and machining them to fit a gasket to them to stop the leak. only a few needed replacing the cylinders for that problem, never the pistons..
Thats the info that I am looking for what actually the TSB from Porsche says.
Lorne M.
83 SC |
P-Zero Burner
That specific TSB "Refacing Cylinder Heads" (as well as many others for the 964) can be found at http://www.pcarworkshop.com/index.php/964_-_TSBs%2C_Parts_Guides
You must register at the site (its free) to see the TSB's
I had also bought new mahle cylinders for 964 & send cylinder head for refacing to a reputed company, now I need to know if i have to do engine timing differently or I need to measure piston valve clearance separately, as head has been machined ... My engine is 964, 91 Carrera 2.
Thanks |
