Send a message via Skype™ to aircooledkiwi
964 Valve adjust
Hi I have one question about the valve adjust procedure on a C4 - does the power steer pump have to be removed or loosened to get the right side top valve cover off? All the procedures that i have read don't mention the pump but it appears to be majorly in-the-way......
'02 S6 Avant
'93 C4
'77 911S Project
Old 12-25-2006, 12:28 AM
ckrause
Guest
Posts: n/a
Just did the valve adjust on my C2 and it's the same as yours....no need to remove the pump... You have to remove a bunch of other stuff however...
Merry Happy!!!
-CKKrause
Old 12-25-2006, 10:07 AM
Bland
unclebilly's Avatar
Did you have to remove the heat shield that runs between the exhaust and the lower valve covers? How many bolts was it roughly?
Old 04-11-2007, 09:21 PM
Yes, it has to be removed to gain access to the intake rockers. Just a couple of M6 bolts. (10mm socket)
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 04-12-2007, 02:51 AM
Bland
unclebilly's Avatar
Did you take off the cat and the primary muffler too?
Old 04-12-2007, 06:37 PM
Bland
unclebilly's Avatar
Despite the fact that you have to dissasemble 1/2 of the car, this job isn't really all that difficult. I'd say it takes ~3 hours to do start to finish whereas on my 77, I can do it in less than one hour.
I am not finished but I not have all 4 valve covers off and will finish up when I get home from work tomorrow. I answered my own question, the muffler and cat do have to come off.
Old 04-12-2007, 08:36 PM
you really don't have to remove the right side sheet metal to do the intake valve adjust.
206 637 4071
Old 04-14-2007, 10:28 PM
RandyF's Avatar
I'm doing my 90' C2 valve adjustment now, so I thought I'd share some photos:
As you can see, the power steering pump does make access to some of the valves on the upper right a little difficult:
So far the most difficulty I've had has been removing the top right cover, but as you can see here, there are only 6 nuts to remove, and none are directly under the steering pump:
The issue I had was one washer towards the back that was a real pain to get off. Without all the washers off, you can't remove the cover. The washer is made of a soft aluminum I believe, and tends to mate with the bolt as the nut is tightened. I tried a lot of things to get this one loose, but in the end it came off with the help of a small screw driver which I dug into the side of the washer to turn and loosen:
Time and patience finally paid off.
...Randy
90 964 - Weekly Driver
2003 Celica - Daily Driver
78 911 SC - SOLD
Old 11-26-2009, 09:48 PM
Pete000's Avatar
I took off my rear bumper which made it really easy to do the valves all from under the car.
Work to Live, don't live to work...
Old 12-04-2009, 05:43 PM
Did mine last year 91 C4 Cab, not too difficut actually but a lot of stuff to take loose. Didn't need to remove bumper or Power Steering pump, just all of exhaust.
Old 12-12-2009, 02:51 PM
