964 RS, bilstein "Cup" ... ID these shocks
964.343.041.80
Those are factory RS Bilsteins, lines up with the part number for the front struts. It looks like someone added the Monoball/Camberplates on the fronts, but its a bit strange that the rear monoballs have been replaced by the factory rubber C2 upper mounts.
PS; they are often refered to as Carrera Cup, as they came on the street USA Cups, but they are not the same as the racing Carrera Cup setup, which uses the smaller diameter spring up front, much larger piston rod, and you would have monoballs front and rear.
2001GT3Cup/93RSA/944Spec#19 Last edited by J Richard; 02-21-2010 at 09:24 PM.. |
i added the mono balls from erp
thats exactly what i thought,,,, thanks |
964RS Bilstein is not the same as 964Cup Bilstein
RS 22mm rod ![]() Cup 40mm rod
they r called bilstien "cup" off of a 964rs euro or the american cups
not the cup car race shocks/stuts got confirm from bilstien |
anyways they r for sale
see classifieds |
