Commerical Pilot
GLASFIBRE's Avatar
993 Headlights
I'm in the middle of a 911 to 993 convert and are ready to connect headlights, the stock connectors are not easy to locate, I've seen a pin out for the back of the assembly somewhere but can't seem to find it again, anybody know the pin out or where I can score a set of connectors......Jack
Old 12-15-2009, 03:35 PM
Cooper911SC's Avatar
Saw your post on 911 forum too...
The connector end is available from Porsche. # 999 650 150 40 ($12.50 from Pelican)
You can also get the individual pins/spades #999 652 871 22 ($2.75)
PET also shows a "Contact Bush" Pelican lists it as a "sleeve" # 999 652 744 20
My best guess is that this may be the foam rubber seal that is part of the plastic connector. It seals the male and female halves.
If you still need the pin outs I can find them in the service book.
Cooper
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 12-16-2009, 09:45 PM
