Headlight issue
Ok just picked up a 91 964 C2, drove it down from San Jose to LA and the light beam was terrible. So i installed Silverstars, they worked when installed and now the low beams don't work. High beams work. There is no power at the 2 fuses, could it be the switch or should I be looking some where else. Any info is appreciated.
Joser
Old 12-11-2009, 06:18 PM
Don Plumley's Avatar
What wattage bulb? How about the relays? If there is no power it could be the switch or the high-beam switch in the steering column.
Separately, clean the inside of the headlight housing with alcohol, the lenses and reflector tend to get a haze the dulls the light.
Don Plumley
M235i
Old 12-12-2009, 01:40 PM
There are no relays for the headlights on a 964, totally stock setup. All I did was swap out the regular bulbs for standard SilverStars that are a little crisper.
Has anyone had a turn indicator lever go out, by looking at the wiring diagram it looks like this controls the low beams from coming on also. I just picked up this car so unsure if the previous owner had issues with it.
Joe
91 Red 964 Coupe
Old 12-15-2009, 10:56 AM
Update
I replaced the turn indicator column switch and that fixed my problem. Have lights again.
Old 12-18-2009, 07:01 AM
