wurls's Avatar
993 widebody?
I'd like to hear from anyone that has owned or currently owns a 993 widebody.
I know the widebody was offered in the C4S model, but was it ever offered in the C4 model?
I've heard that there might be issues with the all wheel drive system on the C4. Any ownership info would be greatly appreciated, as I am considering chasing a 993 widebody instead of a 930 or 965.
Cheers guys!
Wurls
1995 993 Coupe
Old 12-21-2009, 05:40 AM
Don Plumley's Avatar
A C4S has the wider rear flares (widebody) along with bigger brakes. A C4 does not.
A C2S has the wider rear flares (widebody) but standard calipers. A standard 992 (C2) does not.
The AWD in the 993 is generally very robust, and much more so than the prior generation.
Don Plumley
M235i
Old 12-21-2009, 05:49 PM
computamedic's Avatar
The wide body was not "offered" on the C4S - it IS the C4S. The wide body was one of the distinguishing factors of the "S" cars - the C4S and the Carrera S (it wasn't called a C2S).
There never was such as product as the 993 C4 with a wide body.
Regards
Dave
964 Register Secretary - PCGB
1989 C4 wide body conversion
www.964uk.com
Old 12-22-2009, 03:55 AM
wurls's Avatar
Regards
Dave
Dave, thank you for your reply and helping me to figure this one out.
Now that I know that the "S" in the series designation has a wide body, is that wide body the same as the turbo body? Yet another head scratcher for me! LOL!
Thanks!
Wurls
1995 993 Coupe
Old 12-22-2009, 08:14 AM
The wide body on the S models is the same body as on the 993 Turbo. A 993 C4S is basically the turbo model without the turbos.
'96 Coupe - Arena Red
Old 12-22-2009, 08:38 AM
cgfen's Avatar
Cheers guys!
very few if any maintenance issues with 993 AWD system
many potential maintenance issues with the 964 AWD system
Old 12-22-2009, 09:12 AM
Harlan Chinn's Avatar
Porsche for model years 1996 and 1997 saw a slump in cars sales. In order to boost sales and interest in the 993 line, they decided to produce the CarreraS and Carrera4S models using what was seen as a surplus inventory of Turbo widebodies and chassis. These models were all NA engined and the standard Carrera brakes except for the C4S which received the "Big Red" brakes. These two models are distinguished on the outside by the unique split grille on the CarreraS painted to match, while the C4S had the standard black grille. The CarreraS and Carrera4S were imported and sold in North America in 1997 and 1998 and were the last of the "Air-cooled" cars produced. Because of their limited numbers, reasonably priced, good examples are becoming more and more difficult to find.
Harlan Chinn
Pacific Northwest Region
1998 Carrera S ArcticSilverMetallic
1982 911SC PazificBlauMetallic
Old 01-15-2010, 08:02 AM
Bill Verburg's Avatar
and then there is the real 993 widebody, aka GT2
Bill Verburg
Old 01-15-2010, 01:46 PM
The only real issue with the 964 AWD system was that it was very expensive for Porsche to build - hence the replacement in the 993 with the much cheaper viscous coupled system.
There are no maintenance issues with either system - both are very robust.
Regards
Dave
www.964uk.com
Old 01-15-2010, 11:19 PM
993's AWD system is bomb proof. The only thing you need to do is change the front diffs oil. It's less then 1qt.
The downside to the AWD system is a little added weight, & you can't add a short shift kit with out some modifications, due to the torque tube. But the car is more confidant & planted, & almost impossible to spin. You plat it, then floor it, it goes. I must say it's OK in the snow as well.
WB 993's cost more, & will hold their value better then a NB car.
Old 01-16-2010, 09:02 AM
how much wider..
is the C4S, than a NB C4?
Is there a side by side comparison,. picture...somewhere?
I never realized that the NB 993 had such a pronounced flair at the rear. I may decide on a NB 993C4 instead of the much more rare, and more expensive C4S. It would be very nice to see the actual difference.
Old 01-16-2010, 03:22 PM
It's a couple of inches. Most C4S also have a few options, it's hard to find a stripped out one. But my C4 also has a TON of options.
You can tell a NB C4 by the silver calipers.
C4S
95 C4
Old 01-16-2010, 03:45 PM
Now in 993 land ...
aigel's Avatar
Here my C2 (red calipers )
81 SC (sold)
Old 01-18-2010, 01:01 AM
Here are a couple of pics of narrow body up front and a widebody. The difference is where the tip of the tail light touches the bumper distance out to the outer edge of the rear wheel well. The difference is about 1.5" wider on either side.
Harlan Chinn
Old 01-18-2010, 04:55 PM
Now in 993 land ...
aigel's Avatar
I am wondering - do th4 993 folks modify their NB cars to WB (i.e. when the chance arises during a repaint or accident repair)? That sure seems like an easy enough modification while enhancing the car. Are there stock flares available or would they be junkyard items?
George
81 SC (sold)
Old 01-18-2010, 06:04 PM
Some narrow body 993s have been used as donors in creating 993 RSR replicas as seen on several recent Rennlist treads. Documented and done well by a specialized body shop will assure the car retain a higher resale value. A converted wide body car will never be worth as much as a factory wide body may it be a vintage 911 or 993 platform.
Harlan Chinn
Old 01-18-2010, 11:28 PM
Just a quick question without trying to be redundent...am I correct that the earliest widebody would be 1997?
Thanking you in advance,
Bruce
Old 01-20-2010, 12:07 PM
three years
96, 97, and 98. There appears to be many more C4S's built than narrow body C4 coupes's in the 993 line.
I saw build numbers somewhere, 993 registry I think. There were far more C4 cab's and C4 targa's than coupes in NB C4's.
There certainly seems to be NO shortage of availability of high quality high dollar C4S's. I've probably found 15-20 available over the last few nights. Price range's have been $39K-$49K, mileage from low teens to 70K.
I've been researching option codes, color's, and trying to determine if there is a different level of standard equiptment between years. Also been looking at other aftermarket goodies for the cars.
I gotta pace myself, I really didn't intend to buy for another year. Ooh well, maybe the earlier the better. Afterall, the price of wide body "Turbo Look" 911's from model years 84-89 have started to escalate the last handful of years. Five to ten years ago, you could get a beautiful example for under $20K, now you need $30K. It would be just my luck that my latest Porsche passion go's thru the value roof too-before I buy usually too!
Old 01-22-2010, 02:21 PM
Paul K's Avatar
FWIW, I think the best part of the wide-bodied cars and turbos is the front bumper. Way nicer looking than the stock bumper. And the best part is, the turbo bumper can be fitted to a non-turb bodied car, as the front fenders are the same width.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 01-22-2010, 04:26 PM
autobonrun's Avatar
George
I'm sure some may, but I personally haven't heard of many that do this to 993's. My gut feel is the majority would sell their NB and buy either a 2S or a 4S to get not only the different width but the turbo front bumper as well.
I guess with a major accident involving a NB, all bets would be off and someone might just go with the wide body look. Harlan is absolutely correct however about some NB 993's being used as donors for RSR project cars.
Personally, I'd stay as close to stock as I could whether it be NB or WB just to keep the resale value.
As far as the AWD systm, no issues whatsoever with my 96 C4S.
1979 Porsche 911SC Targa
1996 Porsche 993 C4S
2005 Porsche 996 Turbo S
2020 BMW X3M Competition
2003 BMW M5
Old 01-23-2010, 07:51 PM
