USAF VET
onereal_1's Avatar
'89 C4 ABS light
Car has about 92K miles on it, full motor and trans axle rebuilt recently. On a very intermittent occurrence the ABS and Diff lock light comes on. I thought it was from a bad seal in the front diff, so I had my shop redo it. It still comes one. Is there a sensor on its way out? Thanks.
Upgrades / service
SuperBlue Brake fluid
Front Diff Rebuild x2
Dust shield removed
Brake ducts installed via fog lights
Carbo-Tech Panther Plus Performance Break pads
Brake Pad wear sensors removed. (they melted during a track session)
Please help---ITS ANNOYING!!!
'89 964 C4
Old 01-28-2010, 10:22 AM
computamedic's Avatar
As per the Rennlist reply.
Has the car had distributor caps and/or coils replaced anytime recently??? Apart from the problems that are supposed to give the warnings, stray HT voltages are known to cause the ABS/PDAS systems to go berserk. It took over a year to diagnose the problem in my car and new coils and caps/rotors solved it.
Regards
Dave
964 Register Secretary - PCGB
1989 C4 wide body conversion
www.964uk.com
Old 01-30-2010, 02:14 AM
