Wheel spacing question
I just noticed that on my car I had to put a 6mm spacer on the passenger side rear wheel to get it at the same distance from the flare as the drivers side tire. Is this normal? I seem to remember somewhere that this is not uncommon.
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 06-12-2010, 09:18 PM
Newsboy's Avatar
The spacing should be the same on both sides. You shouldn't have to put a spacer on one side to get an equal distance. I believe it's suggested, that if you go over 5MM, you should change wheel studs.
Old 06-13-2010, 04:11 AM
Bill Verburg's Avatar
Cheers, James
It's more normal than you would think.
Some guys(some are very fast too) do run the different spacers on different sides others ignore it.
Bill Verburg
Old 06-14-2010, 06:15 AM
Thanks Bill, I just got the car corner balanced and aligned by Dan Jacobs so i know the alignment is correct. I just mounted 18 Michelin Pilot Sport Cups and was getting some minor rubbing on the inside on the passenger side and noticed that the wheel is in a little further. The car has no damage and I noticed my '72 is similar. Interesting. I replaced the studs and added the 6mm spaced and all looks fine now.
Thanks for the info!
Ayrton Senna
1993 964 RS
Old 06-14-2010, 08:14 AM
Chakka71's Avatar
What size MPSC's are you running & what are your wheel offsets?
PCA National Instructor
93 RS America (some things done to it....)(gone)
85 Carrera (gone)
06 BMW M5 (gone)
"If you ain't first, your last"
Old 06-14-2010, 09:30 AM
I'm running 265/35R 235/40Front. I'm not sure what my offsets are though.
Ayrton Senna
1993 964 RS
Old 06-14-2010, 11:27 AM
Typical 964 fitments for track use are 8ET55 & 10ET65 w/ spacers to get down to ~ ET47
This is Barin Jacobs beautifully prepared RSA, w/ the above wheels and 245/35 & 275/35 x18 tires
Bill Verburg
Old 06-14-2010, 11:50 AM
cgfen's Avatar
WOW
that's a bit of - camber!
2012 Cayman R Chartreuse / 3 pedals
2009 2S Nordic Gold over Cocoa, my sweeties car (Chairman Meow)
2024 Audi A4 Allroad Navarra Blue over Grey
2010 Audi A6 Avant Grey over Grey - Supercharged!
Lottsa "steel is real" bicycles
Old 06-15-2010, 09:58 AM
Originally Posted by cgfen View Post
WOW
He uses every bit of it
Bill Verburg
Old 06-15-2010, 10:33 AM
