Architecture & Porsche's
AC Condensor fan cycles: on 5-6 seconds, off 5-6 seconds
I performed the resistor upgrade 2 years ago but this did not fix the condensor cycling: anyone have any other ideas/thoughts?
Thanks, Mark.
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 07-19-2010, 09:24 AM
Metal Guru
911nut's Avatar
Thanks, Mark.
Did it work properly after you changed the resistor?
Read about the troubleshooting technique here: 964/993 Oil Cooler Fan Operation & Troubleshooting
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 07-19-2010, 11:05 AM
I'll check this page: no, the new resistor did not change a thing: still cycles on/off. Thanks Paul,
Mark
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 07-19-2010, 11:24 AM
