-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   cat eliminator pipe availability? (http://forums.pelicanparts.com/porsche-964-993-technical-forum/549016-cat-eliminator-pipe-availability.html)
e p slick 06-20-2010 12:35 PM
Anyone suggest a source for cat eliminator pipe for 993?
EPS
Oh Haha 06-20-2010 02:21 PM
Porsche 911 Exhaust Pipes - Page 1
http://www.youtube.com/results?search_query=Porsche+993+cat+bypass+Fabspe ed&aq=f
GregB7S4 06-21-2010 06:31 AM
If your car is a 1996-1998 993 it has the OBDII diagnostics. Eliminating the cat may throw a code/CEL. Depending upon emmissions testing where you live this may cause you some headaches. If you have a 1995 993 you should be fine.
Has anyone figured out how to run a cat bypass on 96+ cars without a CEL? - Rennlist Discussion Forums
e p slick 06-21-2010 05:43 PM
1997
I am inclined to swap back and forth every two years for inspection.
Save The Tunafish!!!
hkspwrsche 06-26-2010 06:13 PM
Standalone EMS or The right resistor on the down stream o2 sensor will fix the code. You only need the first O2 sensor for the car to run right.
