e p slick's Avatar
cat eliminator pipe availability?
Anyone suggest a source for cat eliminator pipe for 993?
EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 06-20-2010, 01:35 PM
Oh Haha's Avatar
Porsche 911 Exhaust Pipes - Page 1
http://www.youtube.com/results?search_query=Porsche+993+cat+bypass+Fabspe ed&aq=f
Pacific Blue
Wayne
Old 06-20-2010, 03:21 PM
If your car is a 1996-1998 993 it has the OBDII diagnostics. Eliminating the cat may throw a code/CEL. Depending upon emmissions testing where you live this may cause you some headaches. If you have a 1995 993 you should be fine.
Has anyone figured out how to run a cat bypass on 96+ cars without a CEL? - Rennlist Discussion Forums
Greg
Old 06-21-2010, 07:31 AM
e p slick's Avatar
I am inclined to swap back and forth every two years for inspection.
Save The Tunafish!!!
Old 06-21-2010, 06:43 PM
hkspwrsche's Avatar
Standalone EMS or The right resistor on the down stream o2 sensor will fix the code. You only need the first O2 sensor for the car to run right.
Harold
Old 06-26-2010, 07:13 PM
