Engine running way too rich - What can be wrong ??
Hi -
Just had my transplanted 1995 993 tested on a dyno. Max power showed 250hp/317Nm and and A/F showed way too rich from 5000rmp and up. Last year it did 270hp/342Nm. No changes since then. Engine is stock except for the exhaust which is something homemade based on a flowmaster muffler and no cat. KN airfilter which is nice and clean Any ideas what can suddenly cause this loss of power ? (Im thinking injectors, MAF sensor...) The guy testing this is also specializing in remapping ECU and suggested naturally that he could do a customized remapping using the dyno to correct the A/F and other things as well. Anybody having tried to have done a customized remapping ?? Peter |
The head temperature sender on the drivers side foreward end . The sender thinks it is cold and adjusts the mixture rich like a choke would. I had this happen and found mine hard to start when warm and you could smell the rich mixture when running. I think Porsche also enrichens the upper RPM mixtures to cool the cats
| All times are GMT -8. The time now is 02:24 PM. |
