Danskeren's Avatar
Engine running way too rich - What can be wrong ??
Hi -
Just had my transplanted 1995 993 tested on a dyno. Max power showed 250hp/317Nm and and A/F showed way too rich from 5000rmp and up. Last year it did 270hp/342Nm. No changes since then.
Engine is stock except for the exhaust which is something homemade based on a flowmaster muffler and no cat. KN airfilter which is nice and clean
Any ideas what can suddenly cause this loss of power ? (Im thinking injectors, MAF sensor...)
The guy testing this is also specializing in remapping ECU and suggested naturally that he could do a customized remapping using the dyno to correct the A/F and other things as well.
Anybody having tried to have done a customized remapping ??
Peter
'73 911S Targa black - original
'73 911RS clone 3.6, non-sunroof Coupé
'01 Volvo V70T5 - 320bhp
Old 06-26-2010, 03:03 PM
The head temperature sender on the drivers side foreward end . The sender thinks it is cold and adjusts the mixture rich like a choke would. I had this happen and found mine hard to start when warm and you could smell the rich mixture when running. I think Porsche also enrichens the upper RPM mixtures to cool the cats
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 06-26-2010, 04:51 PM
