Question Tiptronic Question - Acceleration Hesitation
OK, this is my first tiptronic so I have no comparison. When I floor it out of a standing start, I feel a hesitation for a second or so - almost the car is thinking if it should really do this... I know the 0 - 60 acceleration is about 1.5 sec longer in a tip than a manual but is this hesitation normal? Thanks.
'91 C2 Targa
Old 07-17-2010, 03:38 PM
Under normal accel, the Tip is programmed to start out in 2nd gear. If you floor it for a quick getaway, there is a minor hesitation as the Tip downshifts to 1st.
You can do 2 things to have it start out in 1st:
...put it in "manual" and make sure that you drop it into 1st prior to accelerating
...select "3", instead of "D", this will have the Tip starting out in 1st.
LouZ
'90 C2 TIP
'08 Cayman S
Old 07-17-2010, 05:34 PM
