-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   can I use a G50/21 with a 996TT engine "bolt on"? (http://forums.pelicanparts.com/porsche-964-993-technical-forum/559089-can-i-use-g50-21-996tt-engine-bolt.html)
CaymanGT1 08-16-2010 07:24 AM
I'am only referring to engine-to-gearbox fitment. since they will sit in mid engine configuration in a tubular chassie. (gearbox flipped). - what clutch/flywheel combo will work ?
http://forums.pelicanparts.com/uploa...1281968664.jpg
mamut 08-17-2010 05:00 PM
No you can't. It will bolt on to the engine, but the shift controls and attachment mounts are completely different.
CaymanGT1 08-18-2010 12:37 AM
Mounts will ofc. be one-off since it's a tube chassie, and shifter will be a wire-shifter conversion or a sequential shifter conv. - so those two factors I got covered. (note gearbox is flipped - and engine sits between so it NEEDS to be wire or robotshifted)
It's the mount to the engine - and what clutch / flywheel to use that the question
but if the gearbox bolts on (as you mentioned) - can I just use 996GT2 or TT clutch/flywheel then straight off then?
mamut 08-18-2010 06:36 AM
Yes you can, cheers.
