can I use a G50/21 with a 996TT engine "bolt on"?
I'am only referring to engine-to-gearbox fitment. since they will sit in mid engine configuration in a tubular chassie. (gearbox flipped). - what clutch/flywheel combo will work ?
Banned
No you can't. It will bolt on to the engine, but the shift controls and attachment mounts are completely different.
It's the mount to the engine - and what clutch / flywheel to use that the question but if the gearbox bolts on (as you mentioned) - can I just use 996GT2 or TT clutch/flywheel then straight off then? Last edited by CaymanGT1; 08-18-2010 at 12:40 AM.. |
Banned
Yes you can, cheers.
