cgfen's Avatar
993 "big red" brake system plumbing question
Warning, fairly long and technical, but i could use your help.
Specifically my question / confusion relates to the hydraulic pump and pressure reservoir present on Turbos and 4S chassis.
First some data, then the question.
I typically flush the “entire system” at least once a year.
All was well until I started alternating ATE blue / gold.
I can never flush out all the blue and end up with gold fluid in the fender mounted reservoir despite;
• Sucking out as much fluid from the fender mounted reservoir as possible.
• Purging the lines with up to 2L of new gold fluid.
• Clearly seeing only gold come out all 8 bleeders
This time I actually had gold in the fender mounted reservoir and out all the bleeders until I turned the key on and allowed the hydraulic pump to run.
Then the fender mounted reservoir fluid slowly turned blue the longer the pump ran.
I find it hard to believe that the pump is mixing fluid between the pressure reservoir and the fender mounted reservoir, but ???????????
My question is, How can I purge the system and ensure the hydraulic reservoir has new fluid exchange also?
I know there is a bleeder on the pressure reservoir also, and I did drain ~ 50ml from it before fluid flow stopped. Initially the fluid from the pressure reservoir was milky / airy before transitioning to clear blue air-free fluid.
Second question. Is there a 2nd connection from the pump / pressure reservoir to the fender mounted reservoir? Something that would allow mixing?
Thanks for your help.
Craig
2012 Cayman R Chartreuse / 3 pedals
2009 2S Nordic Gold over Cocoa, my sweeties car (Chairman Meow)
2024 Audi A4 Allroad Navarra Blue over Grey
2010 Audi A6 Avant Grey over Grey - Supercharged!
Lottsa "steel is real" bicycles
Old 11-03-2010, 02:59 PM
Bill Verburg's Avatar
The procedure is outlined on pg 47-19 and 47-20 of the shop manual
If you don't have a manual PM me and i'll send a copy
there will be some residual fluid in the abs pump which you will need a hammer or PS2 to flush out
Bill Verburg
Old 11-03-2010, 03:26 PM
cgfen's Avatar
Thanks Bill, i'll check my home computer.
Fairly certain i have shop manual PDF there.
Craig
Old 11-03-2010, 04:46 PM
cgfen's Avatar
Spot on Bill, thanks for taking the time to point me in the right direction.
cheers
Craig
Old 11-04-2010, 08:18 AM
