-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Replacing 993 Engine trays with engine in (http://forums.pelicanparts.com/porsche-964-993-technical-forum/572909-replacing-993-engine-trays-engine.html)
Neil 993 11-01-2010 02:32 AM
Hi,
I have a damaged back engine tray part number 99310621406 and right side engine tray part number 99310628910, these are the internal engine trays.
Does anyone know if you can replace them with out removing the engine?
Neil 993 11-01-2010 02:33 AM
Did not mention, above this is on a 993 carrera manual Coupe
Traveller 11-02-2010 04:59 PM
Originally Posted by Neil 993 (Post 5647884)
Hi,
I can't comment on the rear engine cover, but I know the right engine cover can easily be removed with the engine in place. You do need to remove a few parts. I had it off when I replaced my valve cover seals.
Here is a pic...
http://edelweiss.smugmug.com/Cars/Po...64_7FC2L-L.jpg
Neil 993 11-02-2010 05:22 PM
Thanks for the reply, I guess I will give it a go in replacing the right tray.
Hopefully I get a reply on the rear tray, as I will have to remove the rear bumper, heat shields and exhaust before I find out if I can replace the rear engine tray.
As that will be a big job, possibl with no outcome......
