Replacing 993 Engine trays with engine in
Hi,
I have a damaged back engine tray part number 99310621406 and right side engine tray part number 99310628910, these are the internal engine trays.
Does anyone know if you can replace them with out removing the engine?
Old 11-01-2010, 02:32 AM
Did not mention, above this is on a 993 carrera manual Coupe
Old 11-01-2010, 02:33 AM
Alps Adventurer
Traveller's Avatar
Originally Posted by Neil 993 View Post
Hi,
I can't comment on the rear engine cover, but I know the right engine cover can easily be removed with the engine in place. You do need to remove a few parts. I had it off when I replaced my valve cover seals.
Here is a pic...
All the best,
Alex
1995 Carrera 2 - Speed Yellow - Alps Touring
Old 11-02-2010, 04:59 PM
Thanks for the reply, I guess I will give it a go in replacing the right tray.
Hopefully I get a reply on the rear tray, as I will have to remove the rear bumper, heat shields and exhaust before I find out if I can replace the rear engine tray.
As that will be a big job, possibl with no outcome......
Old 11-02-2010, 05:22 PM
