Active window
I have a 93 C4 and have noticed the windows still work with the key out, even after opening and closing the door many times, hours later. Any sugestions whats wrong? Thanks Todd
Old 12-05-2010, 05:18 PM
Manassas, VA
lucittm's Avatar
Check the door switches. I think the way the circuit works is that power is still applied to the electric windows after the key is out UNTIL you open the driver's door.
There is a good chance that the rubber cover has hardened and keeps the plunger depressed all the time, even when the door is open. Do your interior lights come on as soon as you open the door? Probably not.
Good Luck,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 12-07-2010, 06:44 PM
911jettat's Avatar
With the key out, the windows should work only one time until the door closes.
+2 on checking the door switches.
I had this problem a while back....here's more info: Overnight battery drain - door light switch - Rennlist Discussion Forums
PS: welcome to the forum Todd!
'91 C2 Cobalt Blue
Gone but not forgotten:'90 C2 Slate Grey
R Gruppe bicycles - Cannondale, Titus, Specialized, Bridgestone, Raleigh, Schwinn Paramount, and Scattante TT bike.
Old 12-09-2010, 11:36 AM
