WTB 964 outer stub axle
Redoing my CV's and one of my axle stubs has some gouges. Looking for a 964 stub axle, the one that slides through the rear wheel bearing. pm me if you have one with a price.
Joser
Old 01-31-2011, 03:25 PM
Pic of part I need
Old 01-31-2011, 04:25 PM
I wonder how that got gouged up. It is fixed at the female splined hub. It does not spin on the rear wheel bearing either.
Anyway, I thought that comes with the axle assembly only. You have to buy the whole axle.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 02-01-2011, 05:42 AM
It's gouged up or worn in where the ball bearings sit on the inside of the axle stub. As far as the setup, it does come as a complete unit, but I had a machinist buddy of mine do some work on it. He lathed off the crimp part on the end of the CV cup and then tapped 3 screws for re-securing it. This makes it easier for maintenance and re-greasing. Theres a link on RL on doing this.
Joser
Old 02-01-2011, 08:43 AM
I just did my rear wheel bearings. I don't think the axle stub rides on the ball bearing inner race. The axle stub goes inside or slides into the female splined drive hub which rides on the ball bearing inner race.
I would like to see the 3 tapped holes for securing the stub axle to the CV. That is interesting. Can you snap a pic of the stub axle showing the 3 tapped holes? I wonder how those 3 screws will hold up to the torque because the axle needs six M8 or M10 allen cap screws to attach to the transaxle output flange.
Old 02-01-2011, 09:29 AM
Picture borrowed from RL but you can see the tapped holes. This was done by one of the guys that rebuilds his axles on his race car, so it holds up to torque. Also when I say Ball Bearings I mean the ones in the CV joint not the wheel bearing.
Old 02-01-2011, 10:35 AM
thanks for the pic.
The 3 holes were just meant to hold the CV boot and metal cup in place, so it's not transmitting the torque. It does makes CV disassembly and servicing on the stub shaft end really easy.
good luck on your search for a stub axle.
Old 02-01-2011, 11:10 AM
aew996
C/v
Hi, I probably have what you need but I don't have time to check right now. I will when I get back and advise. I do know I have the complete 1/2 shaft fro a 993 car but unsure of the 964. Will the 993 C/V work on your 964 axel? Not to sound like a moron but maybe someone out there could help? Thanks, I will let you know.
Bill
Old 02-01-2011, 03:50 PM
ahead of the curve
Jeff Burger's Avatar
you can see there is some minor cosmetic damage from removal of the boot cover. there are some marks where the ball ride in the joint but no spalling
email me if interested - jburger657@aol.com
19 Carrera T - MPS member
92 C2 SR coupe M491/ 3.8 look- manual
92 C2 SR coupe cobolt blue- manual
73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy
73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
Old 02-01-2011, 06:10 PM
993 stub axle wont work, it has 48 teeth for ABS not 45 that the 964 uses.
Jeff I emailed you some questions
Joser
Old 02-01-2011, 07:19 PM
Joser,
I don't think there is something wrong with your axle. The rough finish is actually a relief cut for the female spline hub. I checked my axles and they look exactly the same as yours.
Old 02-05-2011, 11:41 AM
