993 C4s From stock to lower suspension
How to make/upgrade a stock suspension lower? Is it expensive?
___________________________ 1971 300 SEL 6.3 1997 993 C4S sold |
There are several levels of suspension improvement, with increasing cost at each stage. Stock suspension is lowered with new springs. Porsche M030 springs bring ROW ride height and reasonable cost. However, assuming you have original shock absorbers, you should probably replace them. There are limited options there. At that point, it's easy to talk yourself into adjustable units, such as Bilstein PSS-10, JIC, etc.
Parts costs are what they are. If you are handy, you can do the labor yourself, but will need a competent shop (that works on 993's) to do the alignment. If you have adjustable units, then you'll also need a corner balance. Welcome to the slippery slope.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
hello,
your car is probably fitted with the original factory springs for the US MARKET, which in my opinion, make your 911 looks like an off-road truck. you can swap your us springs with EU type springs you must check if your car is fitted with m491 or m030 or m033 struts then you can pick the EU OEM springs that match with your suspension system. however, the cheapest trick to lower your car is to buy an EIBACH spring lowering kit 30mm; we have it here in France for 230 bucks then maybe $200 for labor while swapping the suspension springs it might also be possible that few parts like belows, rubber stops, mounts need replacement. its should be a $500 job, parts and labor included hope it helps Cedric |
i forgot as Don Plumey said, a full wheel alignement is needed
+ $120 |
Now in 993 land ...
Good evening All,
Thank you for your comments. I am planning to do this project over winter time. I am setting up my house garage to bring my car from another storage. Will keep you posted with pics. Thank you, Eugene.
Eugene,
You have a PM thanks, AL |
Bump
Finally put out my C4S out of storage! I swapped stock springs with an EIBACH spring lowering kit at a local shop. Looks much better now. Alignment is done too.
I did a little test drive (the car is not registered yet), feels terrible. I was afraid to go over any bumps because it felt like it had no suspension at all. Very, very stiff. Any suggestions.
Anybody out there running the Bilstein HDs on their 993 with stock springs? I've heard they're a good option for those who don't want to pony up the bucks for the coil-over sets. I guess they're moderately adjustable also with external threading.
bump
Max Sluiter
Are you bottoming out the dampers or coil-binding the springs since everything is lower? On a 911, the first thing to hit is the A-arm on the chassis seam right near the crossmemeber/A-arm rear bushing.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
If this is the case, what is the solution?
Max Sluiter
Raise the car up.
Beyond that, it sounds like you fitted stiffer springs and now say the car is too stiff, so...
lowering springs with stock shocks are typically a VERY bad idea. stock length shocks and shorter springs = CRAP in many cases. want a lower car and supple ride? consider MO33 springs and Koni shocks. Did you read the "overview" link that was posted above? it's dated, but has basis in reality, except IMO where it says eibach springs + stock shocks = acceptable ride. Craig ps, i'll bet you won't like HDs either.....................
2012 Cayman R Chartreuse / 3 pedals 2009 2S Nordic Gold over Cocoa, my sweeties car (Chairman Meow) 2024 Audi A4 Allroad Navarra Blue over Grey 2010 Audi A6 Avant Grey over Grey - Supercharged! Lottsa "steel is real" bicycles Last edited by cgfen; 03-10-2011 at 06:33 PM.. |
Your shocks are most likely blown out.
Go with Jic, PSS10's, or Bilstein HD & you should be OK. I just put the factory ROW M030 kit on my C4, it's much lower, rides great, & is factory. The price for the kit was less then a set of Bilstein HD shocks.
