What do these snaps on a convertable boot go to?
I have converted a 911 to a cab and I have a 964 top and boot. The boot fits around perfectly except Im not sure about the very last grey snaps at each end the two that are in the flap that hangs down ny the rear seats. Pics would be great too. Ill have to add these locations for it to snap to.
Thanks Nathan
1981 Delorean |
2nd last snap attaches just above door post in front seat belt (think you can see it here) & final snap is located in the rear seat carpeted area. i think if you pinpoint 2nd last snap as indicated the other location will be easy to judge
Thank you so much. Any chance you could lower the rear seat backs and take a pic of how the top wraps under? Thanks.
1981 Delorean |
but i noticed from other post re "cab top problems" you have now downloaded that older version of PET.....if you ck p.444 of that version you will get a very clear diagram of the boot, snap locations & how the wind "tie downs" are fastened. actually i never used them (just installed the boot with seat backs down & then put them back up) |
