SigmundF's Avatar
Alternator problem – 964?
I have experienced some problem when driving , sometimes the car does not run properly. It feels like it is not getting enough gas, it hesitated during acceleration. This is not a constant problem, it has happened 4-5 times over the last months. I have read that the DME relay is sensitive to variations in the voltage, so I think this could be alternator problem? I have put in a new battery and that seams OK.
I have hooked up a digital multi meter to the battery so I can check the voltage when driving. I have only had a couple short trips so far, but the voltage is constant at 13.4 – 13.6 volt when driving (1000 – 3000 rpm). A couple hours after I have parked the car it shows 12.6 volt.
Is 13.4 – 13.6 low when driving (with normal load lights, fan, radio) for 964?
Any other ideas what the problem could be?
Sigmund
964 -92
911 -76
912 -67
Old 03-09-2011, 02:08 AM
altenator
I had the same problem
1) the alternator was bad (low voltage)
2)check the belt on the dual distributor I thinks this should be your problem
Andrew
Old 03-21-2011, 07:15 PM
Newsboy's Avatar
At idle, your voltage should be 13.8-14.4 volts. Adrian Streather suggests increasing RPM until engine reaches 13.8 volts. If RPM is above 1200, he says you have a problem with your alternator / regulator.
Old 03-23-2011, 03:46 AM
RETIRED
Joe Bob's Avatar
I think that's optimistic.
12.5 at rest
13.0-13.5 at idle
13.5-14.0 at 2500 rpms.
Mine has been like that for years since my SC conversion. I run a Yellow top Optima. Converted to a single belt.
YMMV
2012 ML350 3.0 Turbo Diesel
Old 03-26-2011, 06:21 PM
SigmundF's Avatar
I have now changed the voltage regulator and it looks OK, I hope it stays like that
I now have:
13.7 at idle
13.9 at 2500 rpm
14.0 at 4000 rpm
Sigmund
964 -92
911 -76
912 -67
Old 03-28-2011, 09:16 AM
