Brake help
Hi I need pads for a 97 c4s
There are many sizes for them Which do I need are the front the same as the rear? The calipers look the same? Thanks I just do not want to order the wrong ones. |
the front and rear are not the same the fronts are the same length as the rears but ~10mm taller. Pagid pad#s race front - 1842 rear - 1204 sport front - T5103 rear - T1074
Here is the website which I want to order from
1997 Porsche 911 Disc Brake Pad in Canada - Canada 1997 Porsche 911 Disc Brake Pad |
From this site it's confusing
look here
993-351-949-00-M3 are the Textar fronts that you need, Mintex alternate is listed beneath 993-351-939-01-M3 are the Textar rears that you need, Mintex alternate is listed beneath
