Pics of wheels on 964s?
I'm going to buy some wheels for my 92 C2 cab. Could y'all post some pics with the offsets F&R, the tire sizes and any mods or problems you've had? THANKS!!!!!
7, 8, or 9 16", 17", or 18" ET 52-55
I like the Cup1s on 964 as on this one
what is "ET?"
Did you educate yourself at the page I suggested in the offset post?
trying to pull it up now
seems the selection of wheels is VERY limited for the 964
Stock, somewhat; custom aftermarket, no. Call a big wheel store (e.g. Wheel Enhancement) and they can hook you up with several different options.
For example, I had some Kinesis K28 custom made for my track car: 964 competition wheel setup These particular wheels don't appear to be available anymore, but this is just an example of what is possible.
Kris 1990 C2 2005 CS http://krisu.smugmug.com/Auto/Porsche |
thanks....looks like i'll be forced into cup1s....i wonder if i can get the BBS LMs to work....have you ever heard of them coming in 17" sizes?
Kinesis Super Cups (no longer made). Do not know the offset and I thought they were 17x8.5 and 17x10 as that is what the stamp on the inside would indicate, but when measuring the inside bead width, they actually seem to be 7.5 and 9. Anyways, fit great and you can find these for sale used from time to time. Other options for you include:
Fikse BBS CCW Enkei NT03+M Volk TE 37 Speedline Alesio Speedline for porsche supercups Work Brombarcher (not sure on spelling) |
We're all in the gutter,but some of us are looking at the stars. -Oscar Wilde |
993 headlight replacemant Question
I'm going to help someone replace the headlight and was wondering what the trick is to complete this task. From just looking at it it looks like the rubber band around the lens needs to come off to do this.
Thanks for the help RT |
Canadian Member
Don't mess with the rubber band. Check the owners manual; very simple. There is a lever on the inside of each fender adjacent to the headlight assemblies. Unclaspe the lever and turn all the way towards the windshield, then back 1/2 way. The headlight assembly will pop out. Reverse procedure to replace. Careful changing bulbs; do not touch the bulbs at all with your fingers. Yadda, yadda, yadda........ |
I just saw that I posted this on someone elses thread. Don't know how that happened. I did look in the book but found mnothing about the replacement steps. Do you know what page I need to go to to see hou its done?
Canadian Member
"headlight replacement" in the index will tell you what page to look on.
Otherwise have your buddy order the book "993 Essentials" by Adrian Streather, available at Chapters Book Store. Great manual with pictures showing you how to change the headlights. |
Great looking 964! I've got the same color combo and love yer wheels. |
Metal Guru
RH Speedline replicas:
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Nice rims
1991 Turbo Polar Silver. 415 HP of pure FUN |
There's plenty to choose from but some will require spacers.
Ruf 18s-need spacers ![]() Ruf 17s=need spacers ![]() 18" 996 5 spokes-need spacers ![]() The same but in black. ![]() 993 twists-need spacers for the rear. These are 17" replicas, factory would be 18 ![]() BBS 18s
Gone 92 C2 82 Euro SC race car 993 C4S 3.8 84 Euro Carrera |
ninesixfour- could you please state the size spacers and tires (front and rear) for the 18" 996 5 spoke and the Ruf wheels, please? THANKS!! also any issues with them? ie. rubbing at lock or going over bumps? have you lowered these cars?
