993 C4 brake booster pump issues?
I just purchased a '96 993 C4 coupe and have a feeling there's an issue with the brake system. Upon startup, after the car has been sitting 8-12 hours, the brake booster pump runs for about 30 seconds with warning light on and a little longer after the light has gone out. The pump also cycles -- what I'd consider often -- breifly (5 secs?) during regular driving. At a stand still depressing the brake pedal twice with moderate pressure, or four times with light pressure, causes the pump to cycle briefly, though the light does not come on. Car has 64,500 miles and has been well maintained. I dont remember seeing previous brake issues in the maintenance history. Is this normal or is there a leak somewhere? I'm not familiar with the whole setup. Thanks.
Old 06-01-2011, 10:02 AM
Max Sluiter
Flieger's Avatar
Sounds like there is a bad pressure accumulator somewhere but that is all I can suggest, not having experience with 964s. Welcome to Pelican, though.
Do you have the ECU computer error code reader commonly called the "hammer"?
Old 06-01-2011, 11:07 AM
Manassas, VA
lucittm's Avatar
My warning light comes on after I start the car in the morning. It goes out after 10-15 seconds. It never comes on again until the next morning.
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 06-01-2011, 03:19 PM
P-Zero Burner
911Urge's Avatar
Bleed the entire system if you feel comfortable doing that. There are DIY's all over the place to help you do this. Then monitor the system and see if that changes anything.
Stephen
2006 997 Carrera S - Sport Chrono, Full Leather
1968 912 - Purchased from Vasek Polak in 1971 and still in the family
1989 Carrera 4 - Andial service history, Sold and missing it
Old 06-01-2011, 06:11 PM
cgfen's Avatar
this sounds like typical behavior for a 4S.
My car does the same thing ,but initial start up cycle time is closer to 20 seconds.
the pump is designed to run during drive cycle as you use the brakes and deplete the accumulator pressure.
2012 Cayman R Chartreuse / 3 pedals
2009 2S Nordic Gold over Cocoa, my sweeties car (Chairman Meow)
2024 Audi A4 Allroad Navarra Blue over Grey
2010 Audi A6 Avant Grey over Grey - Supercharged!
Lottsa "steel is real" bicycles
Old 06-03-2011, 09:14 AM
Great - thanks everyone - I'll let it go for now and see if it gets worse.
Old 06-03-2011, 09:18 PM
sml sml is offline
964 C4 ... same
Old 06-04-2011, 06:39 AM
1989 c4
Same problem-three year and no problem and with no change
It looks the nature of c4
Andrew
Old 06-06-2011, 02:51 PM
cgfen's Avatar
what you describe is NOT a problem.
It is a engineered behavior.
sleep well.
Craig
Old 06-07-2011, 12:05 PM
