Alps Adventurer
Traveller's Avatar
Distributor - Purpose of Felt Pad
For over 35 years of wrenching, I've always wondered what that circular felt pad is for that sits in the distributor shaft above the advance hold-down screw and covered by the ignition rotor.
Any ideas?
All the best,
Alex
1995 Carrera 2 - Speed Yellow - Alps Touring
Old 07-16-2011, 03:24 PM
964TargaC2's Avatar
Back in my British car days (MGA /TR3)you were supposed to put a drop or two of light machine oil on that pad..
Old 07-16-2011, 04:47 PM
Alps Adventurer
Traveller's Avatar
That is what I remember reading a long time ago.
If that is the case, what purpose does oiling it serve; there are no moving parts? I remember asking myself that back in the days of VW Beetle ownership.
I'm just finishing off my dual-distributor rebuild and as I was about to put the ignition rotors on, I remembered to install those felt pads I had placed in a small zip-lock bag.
All the best,
Alex
Old 07-16-2011, 04:55 PM
Max Sluiter
Flieger's Avatar
Maybe just a hold-over from non-fixed advance (pre-Motronic) distributors?
Old 07-16-2011, 04:58 PM
Alps Adventurer
Traveller's Avatar
A Rennlister stated that the "oiled" felt pad was to inhibit corrosion.
I wonder how effective it was with an ignition rotor covering it. Maybe to inhibit corrosion of that screw under the rotor.
All the best,
Alex
Old 07-16-2011, 05:01 PM
