acceleration sensor help needed please!
well after fixing my abs ecu i hooked up the durametric scan tool to pull any fault codes causing my loss of abs and traction control.
when i hooked up i got
code 42
fault condition 16 front/rear acceleration sensor
short circuit/line break fault code 42
code 12
fault condition 2 lateral acceleration sensor
short circuit/break in circuit code 11
anybody know what these codes mean and where i should check for the failure . i am interpreting a loss of signal from accelerometers or broken wire somewhere......It was working fine and then i went on holidays for 2 weeks and it was left parked outdoors at a shop with some torrential down pours.I picked up the car with dead battery and check engine light on and abs/pdas lights on.had to boost vehicle to get car home.Now i am left with this issue.I originally thought it might be the abs ecu but i figure if i was able to pull codes it must be functioning.tried erasing the codes with scanner but they return right away.
Old 08-04-2011, 10:13 PM
