Thanks. I pulled the secondary rotor and the belt's definitely gone. Pictures later.
Shawn
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...." -- William Faulkner |
wish I have a good neighbor here who can do my dizzy belt too...
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
I don't think I'll be the one to rebuild the neighbor's distributor. There's some labor in that. And the need for a better timing light. I took my '82 sc distributor apart last year. I had a machine shop cut bushings to fit. (It's documented somewhere on the 911 tech forum.) I was just happy to get the neighbor's car to run on the primary dizzy today (taped up the leads to the secondary coil and wedged them between the plug wires on the secondary cap). The neighbor seems to really appreciate Porsches and I hated to see her car just sitting abandoned. I pulled the DME relay to crank it a few times, hooked up a charged battery, opened the unlocked door and promptly set off the alarm. Fun stuff. Shawn
Just kidding. I rebuilt mine at 84k miles and it was about to break.
The right way to disable the secondary is to disconnect the final stage ignition control unit just below the coil. This way, the coil will not generate the high voltage spark.
Alps Adventurer
I know you said the rotor rotates a bit. That is because it is rotating about the shaft. |
Alps Adventurer
You do not need a timing light.
I unbolted the two leads from the top of the secondary coil (under the rubber cover) and wrapped them up in electrical tape. I don't recall seeing anything below the coil.
Don't you still have to re-set the timing after you put the thing back in?
I have a variable timing light (cheap harbor freight one) that I don't really trust.
Alps Adventurer
The distributor installs in one position only. Gone are the days where you'd rotate the distributor and then tighten a hold-down. |
Meant to post this last night. Apparently there was water in the secondary. (This car leaks some. The tool kit was sitting in a puddle of water up front, some tools rusted badly.)
Anyway, this pic is not for the faint-hearted... Ain't pretty. Arrows point to the belt. ![]() I cleaned it out as well as I could. Oiled it down. Oiled under the felt of both dizzies.
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...." -- William Faulkner Last edited by NOLAsc; 09-12-2011 at 06:37 PM.. |
Alps Adventurer
OMG, looks like it suffered from Katrina.
Now that the belt is confirmed broken, put the rotor back on. It should spin freely with just your finger spinning it around. If not, break out the wallet. At this point, I'd check eBay for a used distributor. |
Also, because of the shape of the gear, be careful when re-inserting the distributor, as the rotors will twist a bit clockwise when the gear mesh. After seeing that picture, I wouldn't even try fixing the thing, just get a used one on eBay or from the used parts forum.
1990 Carrera 4 Cabriolet (silver with black canopy, white leather interior) 2004 Nissan xTerra (Black) |
Yep. If it were my car, I'd drill the pin and pull it apart just to see. Twenty bucks vs nearly a thousand or so. The thousand could wait another day.
But, or course, it's not my car. Shawn
